Yamaha Ox66 Power Issues Please Help!!
The_Chain
Hey guys I have been dealing with power issues on my 2000 Yamaha ox66 250. The last few trips out I have been cruising along around 36k rpm when all of the sudden the motor bogs down like it’s going to stall. As soon as I backed down the throttle 15k or to neutral the motor ran fine, power up again and it would be fine. At first I thought it was sucking air into the fuel lines starving it of gas, so the next time it did it I had my friend drive and I felt the primer bulb which was still rock hard. This weekend I had a complete power loss and was unable to recover. I limped back into the dock, it ran somewhat fine at lower power just above idle, add a little power and it would cycle between running and bogging down almost rhythmically. The primer bulb was still rock hard. When in neutral I can reve it up and it cycle’s fine, reverse doesn’t seem to have the symptoms either.
So if it’s not the fuel or the motor sucking air what could it be, plugs new this yr., new fuel filter this yr., I don’t have water in the fuel, changed with new fuel water separator, I put ring free and Yamaha fuel stabilizer in it religiously.
So guys any suggestions here would be a big help so I can start to narrow down the cause. What are the symptoms of low pressure fuel pumps failing or bad/clogged/dirty o2 sensor.
On a separate note I also noticed my oil reservoir is not filling from the extra aux tank to the fuel reservoir on the motor in the engine housing. I assume this is prob a simple fix?
ahill
Manatee Pocket, FL
More likely low oil in engine resrvoir causing engine to throttle back to 1500.
Check if the oil pump in the remote tank is working.
nitrox32
Shalimar Florida
I have an Ox66 and last summer I had the same problem, replacing the O2 sensor fixed the problem.
The_Chain
I manually filled the tank on the engine and it still had the same issue, I didnt have enough to fill the main aux reservior, I have to fill it next time anyhow..
The_Chain
What might that cost to replace? Can the sensors be cleaned?
grady33
Ocean Pines, MD
I would bet on the low pressure pumps. Easy and cheap fix (3@$35) plus 1 hour or less. If oil pump on reservoir, the one on the engine would run low.
cgmiller
My dad had similar problems with his 150 ox66 and it has turned out both times to be the vst filter, it gets plugged up with small particles from the ethanol in the gasoline..
To be correct; ethanol does not plug the filter. Crap in the tank or fuel delivery system, may get dissolved by the alcohol and get pumped into the motor
Honestly, what else was done to the motor? I wouldn't expect a bad O2 sensor would create the symptoms described. When the sensor gets plugged or the barbell gets fouled, the motor will run richer and perhaps put out more smoke usually black. That may lead to plug fouling after a while but won't result in what seems to be safe mode operation.
nitrox32
Shalimar Florida
The problem I am referring to is the power reduction occurring several minutes after being at cruising speed the engine acted as if the throttle was brought back to neutral if I did nothing the engine would die, If I would retard the throttle the engine would not stall then I could advance the throttle and it would run ok, this would happen only once or twice a trip.
The 1500 rpm thing sounds like the low oil sensor is tripped because the oil tank in the engine cowling is not full enough.
Ok, yes I replaced the VST filter, fuel filter, fuel water seperator, low pressure fuel pumps, spark plugs, checked out fuel pump, but the problem still occurred.
Replaced the O2 sensor and the problem went away. Cost for O2 sensor $300, O2 sensor drawtube $34, O2 sensor gasket set $17....parts ~ $350. http://www.simyamaha.com/category_s/1071.htm
You can clean the parts but some have reported that is a waste of time here is a link on how to clean the parts : http://www.theburningreel.com/forums/bo ... aning.html
And yes I always use RingFree, and use ethanol Stabil in the gas.
The_Chain
So I went and talked with my local Yamaha dealer today....the sugguested that I fill the oil reservior on the aux tank and use the grey primer switch to fill the engine reservior...also change my fuel water seperator again...it could be plugged with crap. Will see if it works it would be nice if it was a simple fix like that....if not I was told to bring it into the shop the mechanic thought the vst was prob gummed up. If it was the low pressure fuel pumps the engine wouldnt even idle right. He didnt have much to say about the 02 sensor when I suggest that.
I will update with tomorrows progress..
family affair
Ohio
It's a combination of LP pumps and o2. When LP pumps fail they flood the engine with excess fuel at low rpm fouling the o2. The fouled o2 causes the cpu to defaults to a full rich condition which also sucks enormous amounts of fuel at higher rpms. With one or two bad LP pumps the engine will idle but the HP pump can't get enough fuel under load at high rpm causing the engine to "throttle back." You will have enough fuel in neutral to Rev the engine, but not under load. Been there, done that.
As for the low oil in the onboard tank, I have no experience.
The_Chain
Well as per my yamaha dealer instructions I went up to the boat this weekend and filled the oil reservior both on the engine and the aux 2 gal tank. I also changed out the fuel water seperator thinking that it had gone bad. Took the boat out in the channel she ran fine, then I opened her up and later full loss of power cut back the throttle and it idled fine, no stall. Dump it into full throttle again and it ran fine a min later same thing...its only when I run her close to or wide open that it seems to have a issue. Whats next...I am thinking and 02 sensor and the three low pressure fuel pumps any other sugguestions....
grady33
Ocean Pines, MD
Definately the low pressure pumps. Had the same thing happen. I would change those before doing anything else.
Salinity Now
Your symptoms sound very similar to the problems I had with my OX66 250, I did EVERYTHING people are suggesting, the stuff I did improved the motor alot, no doubt there, but never truly fixed it when finally I tried a simple step and found a clogged fuel screen on the fuel pressure regulator (sits atop the VST canister) and sure enough, that was my problem.
If you are having hesitation at mid to upper RPM's, stalls, comes back, stalls and boggs down etc, but idles and runs fine at low speeds, I would ABSOLUTELY check that. The problem was severe enough for me to finally commit to just selling the motors, granted I fixed it.....but I was just so fed up with working on them, I let them go with hopes of repowering later.
I think I put a post on here about it a while back, I had a long post about it on THT, (Im in Bahrain right now, so some sites are working, some not so i cant get access to THT to post the link) Do a search on THT for authors "walden75" thats me, you'll see my long read and pics etc on it from the May/June time frame this year.
When I say I did everything, here is a list:
- EVERY filter you can think of (spin on, cotton engine mounted, VST (twice))
-changed all LP pumps
- changed fuel lines
- cleaned, then replaced 02 sensor
- pressure tested and cleaned injectors
- changed injector pre-filters
- new plugs
- fuel rail pressure test
- TPS voltage check
- cleaned and replaced every fuse/connection i could get my hands on (theres a lot under there!!)
- decarbed like nobodys business
Im sure the list could go on.
I cant explain how frustrating this experience was for me, everytime i thought i had it, it would come back, I wasted thousands of dollars on this and (for my motor) it was such an easy fix, just one of those filters you never know is there and not one of the "hot" filters constantly mentioned on the web.
I hope that gets it for you, if not I would certianly check LP pumps, they are an easy test, a 10mm wrench to losen 2 bolts each, prime bulb, see if fuel leaks out, if so, its bad.
The VST is an easy change, 10 or 12 phillips head screws to loosen the tank, VST turns to come off, put a new one one and click your done. As noted, the VST gasket is very skinny and hard to put BACK on, new is always prefered, but putting it in the freeze once you get it off, will help it shrink up for re-install.
I just found my post about this on this site: viewtopic.php?f=3&t=18327&p=115656#p115656
Thats the little SOB piece of crap that ruined my 2011 offshore season.....I think its fuel line deterioration from the return line of the HP fuel rail. That line stays at 36psi all the time when the motor is running, so after enough years of use, heat, Ethanol gas, Im sure its breaking down inside.
Good Luck!!!
family affair
Ohio
SN,
Do you have any more detail or photos of where to find the screen. I could not find mine on our 225 when I last worked on the engine.
Tucker
Port Deposit, Maryland
I wouldn't get near the VST without a shop manual. The pressure regulator is on the upper rear of the VST. It has a vaccum line T'd into it. You can see how the screen mounts by getting on boats.net web site and finding your motor through the queries. Don't recall if there is a gasket where it bolts onto the VST. But I would be real slow when pulling it off. Be sure you don't pull off any vacuum lines when reinstalling it.
Salinity Now
The pressure regulator is on the inboard/backside of the VST, its on the top of the tank, its small, has some strange looking fixed bent tubing coming off it with as Tucker said, vapor lines as well, very brittle if ten years old, as mine were.
If you can see the attached image Im going to post, the filter Im speaking about is part # 13, the entire fuel regulator sits inside an almost "compression" style fitting, it is bolted to the VST top, but the fitting itself is compressed on to a flange nipple coming off the VST top, not to tight to move, but I was expecting it to just come right off when I removed the bolts, when in fact it has to be wiggled off.
Once its off, the filter is plain as day to see, small, but right there (what a PIA too.....Yamaha really promoted Mechinics some job security with this one, even though 3 mechanics I took it too never found it)
Its easily cleaned and reinstalled, gaskets are large and easy to replace on it. Now, I did take my VST top off to get to this, If I remember correctly, you have to, to get access to the regulator.
Hope this helps, hope you find it, if you do, take some pics of the screen and debris like I did, Im curious how much yours has compared to mine.
OK, tried to attach the Boats.net file, but says the "Board Attachment Quota has been reached".....so, go to this link: http://www.boats.net/parts/search/Yamah ... parts.html
Good Luck!!
I would suggest that if you are going to change or clean the VST screen, that you do only that task. Although all the maintenance items mentioned have their place, doing a bunch of things can make it really difficult to troubleshoot if something gets done incorrectly.
With respect to the VST job, there are lots of posts on what to do but here is my two cents:
Do the job on land
Drain the tank using the lower drain plug, a container and a rag. If the motor was recently run, there may be pressure in the tank, watch your eyes.
Stuff rags in the lower cowling to catch the screws and washers that you will be dropping:)
Make a note of the order of the mounting bolts/washers/spacers.
Those washers and spacers are not physically connected to the VST, they are just stuck there and usually some or all will fall off when you pull the bolts out. That is why I advise noting the order of the parts before pulling the bolts. When the parts fall , the rags in the lower cowling will stop them from sliding into the mid housing, something you want to avoid.
Do no cut/unscrew/unclip ANY hoses or lines. It is not necessary to swing the tank out
The screen needs to be twisted to remove. It twists ( to me) in the opposite direction I would expect.
be careful of the pump. Do not try to remove it or play with the float.
The screen may look clean even when it's plugged. If you look through the hole in and through the mesh, you should be able to make out shadows. If it is opaque, it is plugged.
The gasket (rubber ring) often won't fit back in the grove. Freezing it may help, it may not. If it is damaged or kinked, you need a new one.
To keep the gasket aligned, some folks use Vaseline to hold it in place. I use marine grease. Some use RTV adhesive but that makes the next job more difficult.
Pump the primer bulb after the tank is reassembled and mounted to get fuel into it. Do not turn on the ignition with no fuel in the tank. It will take a lot of pumping. Running the pump dry can damage it
