ausway said:
Would anyone out there have 208 Adventure with Yamaha V6 F200hp to tell me on what hole is the engine bolted .
Mine is on a third hole from the top and I've got a feeling it may go one more (last one ) .
here is a short video [youtube]https://youtu.be/wVzgLbzfab4/youtube
Height can depend on hull year. The earlier 208s are lighter by about 200 lbs. The later years have ballast added up front to help balance the added weight of the 6 cyl 4 strokes.
Here is Grady's recommendations for motor mounting height
MOUNTING THE OUTBOARD MOTOR
WATER LEVEL GUIDELINE (4-STROKE ENGINES)
If you replaced 2-stroke engine to 4-stroke engine which has the same horse power, a boat tends to
become “stern heavy” because of heavier engine weight.
As a result, water line will rise and get close to the power head.
This effects a poor engine performance, and water could easily enter into the cylinder(s) and damage
the engine.
Therefore, you should consider the water level guideline to install 4-stroke outboard motor.
Under mooring of boat with a maximum boat load, maintain the minimum height (H) shown in the
illustration between the water surface and the clamp bracket seating point.
Minimum height between water surface and bracket seating point
Model Min. height (H)
Carbureted F2 – F60 150 mm 5.9 in
Fuel injected F40 (4-cyl) – F70 100 mm 3.9 in
F75 and above 100 mm 3.9 in
