Advice on possible 232d purchase
mheltunen
Michigan
Hello everyone, I’m considering purchasing a 2000 gulfstream 232d. It has twin (same year) 200 Yamaha Hdpi motors but one has a blown power head. No trailer as well. The electronics are a bit dated but functional. What are some of the problem areas I should look for? The boat appears to be in good condition. I do realize this is a 18 year old hull but with proper maintenance I would hope to get 10+ more years from it. Any advice is appreciated. Thanks
magicalbill
Indiana
Great boat; I own a 2007.
I will let the more knowledgeable people than myself advise you on potential problem areas with the hull and accessories.
I can say that if it is economically feasible to repair the blown powerhead, you will have the absolute perfect power for that hull. I have twin 200 four-strokes and I love it. (2.0 to 2.1 at cruise,(37-3900 RPM 30-31MPH) Your HDPI's will likely match or better those numbers, plus being they're 2-strokes, you'll have more low-end torque, translating to easy planing. As an added bonus, I have heard more than one party say they are the best engines Yamaha ever made. I would certainly explore the option of repair.
Keep in mind, I like 2 strokes; I don't care about the smoke, and they take me back to my youthful boating days before life got serious..
If you stay on Lake Michigan and out of salt water, you'll likely have 10 good years or more out of that rig.
mheltunen
Michigan
Thanks bill, I’m not the type of guy that goes thru boats quickly and I’ve been looking for one that I’m able to repower. The 232 platform to me seems like a perfect fit. Being a freshwater fisherman a saltwater boat gives me some concerns but finding freshwater Grady’s are rare and expensive. I anticipate some electrical gremlins but I’m fairly good at troubleshooting so I think those are something that I can take care of myself. The seller has been very up front with me on the history and any existing issues so I feel comfortable with that. He has it listed on the hull truth.
jcacchio
I can highly recommend the Gulfstream. I started with the 228 Seafarer, then went to the 268 Islander, and now have a 2002 Gulstream with twin Honda 130s. I think it is the best riding boat of the 3. I can go 40 miles offshore or fish in the bay. I love the versatility and the size of the cockpit is great for fishing.
artodea
Boston Northshore
The Gulfstream is a great boat (admittedly, I'm biased) and I agree that twin 200 power is ideal. Docking can certainly be a challenge with a single.
With a Gulfstream at that age be prepared to replace the thru-hulls at the waterline if they were using plastic parts in 2000 like they did in the 90's. I replaced mine with bronze and it wasn't too hard to access everything you need from the inside. The scars have long healed. Also, the wiring on these boats is all non-tinned copper so any electrical gremlins can usually be cured with a couple spools of tinned wire and heat-shrink crimp connectors. Replace your bilge pump hoses if they are original to the boat, even if they look sound. Check the scupper drain hoses for cracking and replace your fuel lines if original. The condition of the fuel tanks is best done by removing the center hatches.
Check the transom for any movement or weepage from the bracket bolts inside the hull - they are usually quite solid. The powder coating on the bracket might start showing signs of corrosion by now but that is easily addressed with a wire brush and some epoxy paint. Pop the hatch and verify that the bracket is dry.
Also note the hull sides above the water line is balsa-cored so knock test it all over to look for delamination from water intrusion.
Good luck!
mheltunen
Michigan
Thanks everyone for the excellent feedback. At this time I have decided to wait until spring. Winter closes in quickly in northern michigan and my timeline and schedule are too tight to go ahead with the purchase this fall. This being said, I am going to be in the market for a Gulfstream 232D this spring and will post a WTB add over the winter on here. If anyone has any leads on future vessels for sale or if you are intending to sell this coming spring please feel free to send me a PM regarding what you may have available. My budget wil be around the 25K price point. I hope to find one 1995+ but will consider a tad older depending on the vessel. A hardtop and yamaha engines on a bracket are a must and a trailer is preferred. Any help or advice is appreciated. Email is (mheltunen@yahoo.com)
Thanks, Mark
