I asked on this board and a few others what the performance differences woudld be with the two different props. Others have chimed in and gave some guidance. Without boring you with all the details I will post the basics below. Yes, I am well aware we are supposed to use knots intead of mph on the water (and the air), just trying to follow Yamaha and Grady's performance reports.
2006 Grady Marlin almost every factory option (less generator), bottom paint, curtains, 24' outriggers, 100 gallons of fuel, 15 gallons water, four adults, about 200lbs in misc gear (tools, flares, etc). Twin counter rotating 2006 Yamaha F250 outboards.
With freshly 'tuned' Yamaha 15 1/4 x 19" Saltwater Series II props I got the following:
At 4000 rpm I burned 16.8 gallons per hour at 25.3 mph netting 1.51 mpg (this is the best I could get at any rpm above 2000rpm/8.9mph)
At 6000 rpm (wot) I burned 44.5 gph at 45.4 mph netting 1.02 mpg
From 4000 to 4600 I was able to get at least 1.4mpg (speed was 25.3 to 33.7 mph)
With new Powertech 15 x 19" OFS stainless four blade props I go the following (equal load)
At 3500 rpm I burned 15.1 gallons per hour at 25.4 mph netting 1.68 mpg (this is the best I could get at any rpm above 1500/8.3mph)
At 5700 rpm (wot) I burned 44.5 gph at 45.3 mph netting 1.02 mpg
From 3500 to 4600 I was able to get at least 1.4 mpg (speed was 25.4 to 36.3 mph)
On a recent canyon run (with the three blade props) we burned a total of 195 gallons, this included a rough ride out into 4' seas and many hours of trolling. With the four blade props on the same trip I am expecting to burn about 175 gallons. In the ranges we typically cruise at we are doing about ten percent better on fuel burn. If anyone wants my fuel burn charts (MS word) as a reference just shoot me a pm or email.
