- Sep 1, 2013
- Allentown, PA & Friendship, ME
- Offshore
So... I've started to tackle "the project". Bought the boat, with my brother, near the end of the season and knew the floor was soft so I had planned on doing this over the winter. I built a wooden structure off the aft corners so that I could shrink wrap the boat "high". That way I would have easy entrance into the boat during the winter and I was able to use 4'x3' shrink door. I put a small space heater in there and it's actually been quite cozy! So far, I've got the floor skinned and all of the plywood (was in squares) removed. I also tore into the bulkhead that runs behind where an aux fuel tank would be and I'll rebuild that, as well. I'm going to leave everything open till the Spring to make sure anything that is still wet dries out nicely.
I found that a shingle removal tool worked great for separating the top skin from the plywood. The Wonderbar worked well to to do the initial loosening, but the added weight and length of the shingle tool was much better for the bulk of the work. The oscillating tool was great to use for dong the initial cut through the top skin as it doesn't really make any dust like a rotary tool (circ saw), although not as fast as a circ saw. I initially used a straight cut-off blade (in picture) to remove the remaining wood, but I found that the "stiff scraper" attachment worked better for helping to separate the plywood from the bottom skin.
