- Sep 13, 2007
megabytes said:Ditto on RainX. You can run in spray w/o the wipers. It does wonders. DO NOT use it on the clear vinyl. BW and WM have something called the Absorber which is a chamois but works really well. I use it on glass and vinyl after washing and never have water spots.
capt chris said:Straight white vinegar and newspaper clean glass windows anywhere. The vinegar will also kill any mold you have around as well. It's cheap and readily available. I keep it in a spray bottle on the boat. Enviornmentally friendly and works great!
Tony-Sally,tony-sally said:capt chris said:Straight white vinegar and newspaper clean glass windows anywhere. The vinegar will also kill any mold you have around as well. It's cheap and readily available. I keep it in a spray bottle on the boat. Enviornmentally friendly and works great!
capt chris will the vinegar work on the
black mold in the bielge area?
I've heard bleach isn't good for the
gel coat in those areas
Tony
