Seems like all of a sudden it stopped blowing cold air. looks like the compressor works because i can tell from the voltage drop on the AC panel. how do i access the AC unit? Anyone know whats going on with my unit? Thank you
The operations manual should explain how to do a "reset" using the control buttons. I didn't have an owner's manual but found this downloadable manual very helpful:
In case you didn't try this already, check the coils behind the intake screen to see if they're iced over and if so, melt them with a hair dryer. I have a '99 Marlin and the symptom you describe is what happens when my coils get too much frost on them which often happens when it's humid out and I run the a/c for a while.
i checked to coil and its fine. i went through the display settings and still no cold air. i hear the compressor kick on and i have a steady stream of water discharging. i took the fridge out and everything looks good. all electrical connections look good. at this point i have to assume that i need R22 in the system. trying to find someone to service it is almost impossible. any more input would be greatly appreciated. thanks for the manual link it was very helpful. thank you to all.
