1988 Tournament 19: Hull & Trailer Value?
gw204
St. Leonard, MD
What do you guys think an '88 Tournament 19 and '00 Shorelander single axle galvanized roller/bunk trailer would bring w/out power? Found the motor I want on the above rig, but seller is unwilling to separate.
Boat
-New epoxy coated 45-gal fuel tank installed in '00
-Vista top w/ 3-sided enclosure
-Semi-custom cover
-Stbd. captain's chair
-Port back to back seat
-Solid transom and decks
Trailer
-712A Powerwinch
-New springs
-New tires
-SS hardware
Just trying to figure out if it's worth picking up the whole package, pulling the motor and then trying to sell another unpowered boat...
boat valuation
hey i work in boating insurance, so the best way for you to get a correct estimate would be to go to yachtworld.com, you can punch in the yr, length and model of your boat, that could give you a rough estimate
Yep, I had done that. Several on Yachtworld in the '86 to '92 range. Some w/ a trailer, others w/out. All had original power. Prices were from $7,450 to $10,900.
Similar selection on Boattrader, but wider price range.
I would probably go forward with buying the entire thing if I were reasonably sure I could get $2,000 for the hull and trailer. But in this market, who knows...
