I live in Grorgia and am looking at a 1988 fisherman 249
Here is the info:
1987 I am told that it was subject to a recall on the hull in 1997? Owner states that hull replaced and new tank installed by grady
Boat is Overpowered with 2 1999 200 Yamaha Saltwater Series II Motors that have just over 200 hours since new. There are no trim tabs and it appears that a custom aluminum ? doubler was installed on the transom to strengthen the transom.
Boat was not bottom painted and has been stored indoors since 2000 on the rack
Older Garmin unit and vhf
digital Yamaha gauges.
Boat appears clean motors have not been run in a year so i am assuming that a full and complete service will be required. Woodwork needs to be redone etc, Engines are exceptionally clean based on exterior appearance and when removing the cowls.
Boat has tandem axle trailer in good shape.
New to Grady's. I have always been interested in newer boats but in the current economy owning something free and clear is preferrable and more enjoyable in many ways.
What would you pay for this boat? I see very little info on these. Also for you experts out there what will it cost to completely go through the motors to make sure they run perfect?
Any past owners have one of these? Also what are the opinions on the overpower? I am assuming that the 200's are same or similiar in weight to the 150's?
PS Open transom model not on bracket.
Will use for fishing , diving and cruising
Thanks!!!
Here is the info:
Thanks!!!
