1989 Grady White Overnighter20 throttle cable&prop quest
mschetram
Hi guys wanted to know if anyone knows the length or part number for the throttle cable from a 1989 overnighter to a 04 yamaha 150. I am repowering and want to use the old throttle to snake the new one in so I don't want to remove the old one yet. Also the correct prop size for this motor? Thank you for any assistance.
The old steering cable should have its length printer on it. You might be able to still read it. Sometimes the part number ends in a 2 digit number which is the length in feet. Some older cables came in 1/2 foot increments, newer ones are in foot increments. You can also call Grady and ask. They will look up the spec for you.
On the prop, I can't say. 2 stroke or 4 stroke? If you want to get a new prop, find a good prop dealer. They should ask some questions about the boat, the motor and how you use the boat.
