2004 Grady White 257 Advance. Looking for Parts or Part numbers.
Sharkbait1
Can anyone help finding Part numbers.
It takes Grady White a bit of time to get back to me and I am in a bit of a rush to get parts.
I am looking for the Following.
2004 Grady White 257 Advance (Maybe same part for all Grady White Models)
- 3 Thru hull fitting - they are the 3 smaller Stainless fittings on the outside hull of the boat (Not the ones that would be below the bottom paint line)
*1 is for the / Port, Bow, fish box
*1 is for the Bilge / Port, Stern
* 1 is the transom fish box / Starboard, Stern
- 2 Deck Floor Drains.
- 2 transom Lower Well drains
- 1 Fresh water washdown cover
If anyone could get me the part numbers that would be amazing!
Having my boat painted and fittings replaced. They are all corroded.
Thanks in advance.
Thanks in advance.
All of those fittings are standard fittings. your local marina or west marine can help. Measure the size of the hoses connecting to the fittings and that will tell you the sizes you need. Or the hoses should have the I/D and O/D stamped on hose exterior.
Here's a link to the 2007 Grady White parts manual online. I'm not sure if all of the parts numbers are the same between the 2004 and the 2007, but I do have a copy of the 2004 saved on my computer. I just tried searching for it on Google, of which I couldn't find it and am not sure if they took it down from their site or whatnot. But I do have a copy of it in a pdf format, if you or anyone else would like a copy, I can always email it to you. Good luck either way.
This might help for sourcing the parts..
I understand the challange. Yes there are many suppliers of the more common parts but it isn't so easy selecting the right part without first removing the old part and having it for reference. So if you are doing a restoration or upgrade and the boat will be on land for a period of time, you have the luxury of matching fittings.
That works for plumbing and to an extent electrical parts but there are many manufacturer specific parts like trim, panels storage locker parts etc, they will be difficult to locate.
I suggest you take a look at a few online catalogs of a few of the major hardware manufacturers to get an idea of what is available:
The manufacturers that are commonly used are Southco (hardware), Gemlux(hardware, Perko(plumbing fittings and hardware) , Xylem(Jabsco pumps and plumbing),Teleflex ( cables and steering etc). and Dometic (sanitation, plumbing, HVAC). There are more but the above will keep you busy for a bit. I am sure others will chime in with other company suggestions
