2006 Freedom 225, Yamaha 225 OB Radio Interference
HomeTeam
Tournament 225
Folks - Have interference with radio unit while engine is running. Only for radio function - if i play a CD, there is no interference. Once i turn off engine, there is no radio interference. Any suggestions?
Check to see if spark plugs wires are fully seated on both ends of the wire.
Were plugs changed recently? If so, check to be sure they are all correct and none are cracked.
Inspect other ignition components for anything out of the ordinary... and whatever seasick tells you I missed.:)
We're plugs changed recently? If so, check to be sure they are all correct and none are cracked.
Not changed recently, but may not be fully seated. Maybe this is a good reason to add them to maintenance list for the Spring! Thks, and will do.
