22 foot Freedom/Tournament/Seafarer trailer measurements
wlewis
Savannah, Ga
I'm setting up my old Gulfstream's trailer to fit my new Freedom 225 and wondering if some of you 22 foot Freedom/Tournament/Seafarer owners can help me with your trailer measurements. Specifically, I need the distance between the two bunks and the height of your front roller that contacts the front of the bow above the bow eye, above your trailer frame rails. Many thanks,
Walter
Graybeard
I just happen to have a brand new Freedom 225 on a new bunk trailer sitting in the driveway. I'll take some measurements weather permitting because we are supposed to get a wintery mix tomorrow here in Annapolis, Md.
Doc Stressor
Homosassa, FL
Here's how my 226 is set up.
Front roller: 34.5" to center bolt from trailer tongue
Rear bunks: 49" inside to inside
Graybeard
The bow roller is right above the bow eye and the outside edge of the10' long 6" wide bunks is 2' away from the chine.
wlewis
Savannah, Ga
Graybeard,
Would you mind giving me the height of the front roller above the trailer frame rails/tongue and distance between the bunks? Since my boat is in the water, I don't know the distance between the chines nor the height of bow eye relative to the trailer frame rails. I'd like to set up the trailer before pulling the boat out and onto the trailer. Many thanks.
Walter
Graybeard
OK I'll measure that today and get back to you later. I think it's 3.5 feet between the inside edges of the bunks. But I measure it to be certain
Graybeard
OK the centerline of the bow roller is 35" above the frame and the distance between the centerline of the 6" bunk and the centerline of the hull is 22 inches.
