24 offshore fuel tank sending units
Barometersoup
I have a 241 offshore with factory main and aux fuel tanks .. The gauges have both quit working, I am just going to replace the sending units ,gauges and the wiring ...my question is .. Does anyone know the correct length sending units to use? The boat is still in the water so I want to have the right parts in hand when I do the job ... Thanks
igblack87
Barometersoup...I had a similar issue with my 180 last summer. Super easy to fix and easy to get the right length. I called Grady and they were able to give me the length of my sending unit in the tank. Use WEMA USA to order the new unit...Grady uses them in their initial builds from the factory.
Here is my initial post from last year:
viewtopic.php?f=2&t=21766
Here is the WEMA USA site:
http://www.wemausa.com/
Hope this helps you out!
Ian
Barometersoup
Ian,.. Thanks for the info.. I searched the threads before posting , I some how missed yours..I will be calling GW...
Thanks again,.. Gary
