Does anyone have their main tank (93 gal. if I recall?) located in the rear hatch? I want to put my new tank when the time comes in the rear compartment and use the front one for my batteries/electronics/holding tank/parts and tool storage area.
Here is a picture showing what was my original plan:
Now I'm thinking of rotating the entire hatch 180* and using it to cover the front sump. Reason being is it will be under the bimini/enclosure and I won't have to worry about making it a water tight seal for rain water/water coming over the transom. Also my wiring will take less of a beating being in the front compartment.
The only issues I see with doing this is that the rear sump looks shallower then the front sump. I didn't have a tape on me but just from looking at it I thought I could tell a difference. Not a big deal since my tank isn't made yet, but would I still be able to get the same amount of fuel capacity.
The other issue I see is will this put the transom a lot lower, or effect how the boat performs? I'm not sure how the boat sits normally, I would imagine like my 22' seafarer with the transom low and water bailing out the rear (22 has a closed transom/bracket setup, 24' has the open transom).
Looking for as much info as possible from members with this setup, or similar. Thanks.
