cdwood said:
Be careful going from one battery to another while engine is running. Think you might be asking for trouble doing that.
Think I read that you can take out your alternator doing this.
The selector switch has a constant bus-bar from 1 to all to 2. No problems there for switching.
The rest of the advice is sound. It's really best to keep a good cranking battery in reserve, fully charged. A second charge circuit from the outboard is the best scenario to do this. Otherwise, run on the one that will deep cycle best and recharge it when shoreside and can put an electronically controlled charger on it. And if you don't have a second charge lead for your reserved cranker then monitor it's charge level and switch to it when running to keep it fully charged.
You need either a very accurate volt-meter or for lead acid types, a hydrometer. That way you can keep track of where you're at with them. You do have the volt vs. charge state chart on hand or committed to memory, right? The dash gauge is a poor substitute, but a rough indication nonetheless. I'm not even going to get into the various battery types, like gels, absorbed mats, and etc.
A starting/cranking battery will not survive long if deeply discharged very often, or left partically charged. It will end up with sulfated plates and cease to fully charge or hold a charge. If you disconnect your batts for storage and come back in a couple of weeks with a 50-70% charge left, you know its days are numbered.
An isolator is just a stop gap. It connects them when the charging ciruit is live, so a disparity in charge level or capacity can cook the good one as wanderer has said. Batteries can be grounded together, it's not 'till you connect the positives that they become joined in the circuit. That's why banks in parallel must be changed out/replaced in sets, like for like. Otherwise its not important as long as you keep them independent, individually or like for like banks.
EDIT: I was just thinking...I've seen a bad cell in one of a pair or parallel set and the good battery will get cooked from overcharging because of that one bad cell. I have also seen a bank of three or four where they replaced just one out of the set and boiled its water out and cooked it. They stand there scratching their head wondering why that new battery went bad so quick. The poor battery company gets left holding the bag. :cry:
