You are kind of in a pickle. If you want a good look at tuna /swords drifting at night, you are much better off with a "High and Wide" like the B175HW or now they have a B175MW Medium & wide.
They have extremely wide beams to see whats high up around the boat but, of course, these don't read deep bottom. But, for tuna and night swords you don't need bottom. The chart will tell you close enough how deep you are.
For tilefish and day swords, you need to read bottom past 600. B175L will get you that. B265LH too. They make an M265LH in-hull also.
For really good deep bottom readings you need a 2k sonar and transducer.
I have a 2KW GSD24 sonar and an R199 in-hull for deep fishing. It reads bottom past 2000. never fishing that deep anyways Reads squid & tilefish in 800.
I use the GT51M for everything but tilefishing. However, most of our tilefish come from 450 to 700 on the West Wall of the Hudson.
Tried deep dropping swords once with no luck. Hoping to get more chances at that.
I wish I had a B175HW or MW for tuna fishing.
