Hello Fellow Grady Owners! I'm hoping someone here has had a similar issue or might be able to assist me with what I think is an electrical issue.
I have a 2016 335 Freedom with 350 Yammis with about 230 hours. I was recently having some work performed and noticed that the auto-retract for the trim tabs kept cycling every 3-4 minutes. The boat stays plugged in with the batteries off and charger on. When I turn the batteries on the helm lights up, Yamaha screen shows "Yamaha" and then turns to just a dim backlight screen (no data), the binnacle lights up and the tabs are illuminated. Note - the ignition is off at this point. A few minutes later the binnacle lights go off, Yamaha backlight goes black and the tabs are no longer illuminated. A minute later the cycle starts again and on and on.... It's worth noting it does the same thing if the ignition is on (motors off). All of this is happening while the boat is on the charger. I have techs looking into it but they've been scratching their head so far.
The batteries are about 1.5 years old. I'm wondering if I have a battery going bad and voltage is dropping? Any ideas what may be going on??
Many thanks!
Many thanks!
