Decided to tackle the VST filter this year on 2007 F250 Yamaha's with 373 hours. After seeing the filter element I was glad to change them.
I had a lot of what I guess was phase separation in the fuel last year. I would dump the filters out into a jar and you could see what looked like heavy varnish settle to the bottom.
Also did the cylinder head zincs. Found 3 or the 8 ports between has seals that were starting to go bad and deteriorate causing some pitting of the sealing surface.
Also all 4 thermostats. One head had some deep erosion were the brass from the thermostat is very close to the aluminum.
Then I am doing the dreaded Fischer Panda water pump impeller. You may want to hire a contortionist from Circus De Soleil for this. It is doable.
Best thing is to get a set of very long seal picks with the different angles at the tip to help catch the wing nuts and lock washers and it does help when installing them.
https://www.flickr.com/photos/49595913@N02/13438269454/
https://www.flickr.com/photos/49595913@N02/13438409274/
https://www.flickr.com/photos/49595913@N02/13438183313/
