84 197 Tournament deck drains
84grady197
Wellington, Ontario
Tournament 192
Morning all!
I know this subject has been covered very well. From everyone’s posts I’ve decided to replace my very old and dry hoses with 1 1/2” sanitary hose. Ordered new scupper through hulls. Now all I need is the deck drains. Having a hell of a time sourcing these. They aren’t terrible and may keep them if I can’t find something that will work. They are a narrow flat flange (2”). Looked high and low. Anyone here in Belleville (Ontario) area looks at me like I have two heads.
does anybody know what Grady would have used way back then? Or has anybody done a similar vintage with a similar fitting? I’m pretty sure that all the 19 tournaments from that era drained the same regardless of drive type. Any insight would be appreciated!
Can’t help on the drains, but since you have them out, take one with you when you buy hose. I started with inch and a half sanitation hose for my replacement, but it was too large to clamp down leakproof on the fitting. I ended up using inch and a quarter sanitation hose and flaring the end just a bit with a heat gun.
Let’s see a picture of the deck, where the drains fit. If you have room for a wider flange, that is the way to go. How many are you replacing?
I went with a stainless thru hull fitting, turned the od down to match what your looking for. Didn’t want to go plastic.ECC58FD9-F432-45CC-8788-041C935B25A3.jpeg
Will try post a pic when I get the boat back from shop. Not much room for bigger flange though. Already holds a small amount back on the lip. Any bigger and more water will sit.
