Hi Everyone,
I have an '89 Sea Farer with a non-functional washdown and livewell. Before i start troubleshooting, i was hoping someone had a picture of the plumbing layout and wiring diagram i can see. I can ID the washdown electronics as its visible and should be easy to test the motor.
Does the live well have a separate pump? I'm beginning to think it uses the washdown pump, but my boat doesn't have the two-way water valve to select one of the other, which some posts seem to indicate. It may have been changed by a previous owner.
The toggle switch on the console selects either livewell or washdown so i think it may have had two pumps. Where would they be if there are two? Would one be under the live well? I'll never be able to get to that for maintenance, so it doesn't make sense that there would be one there. The fuses look good and ill test the wiring soon. Just need to know if i should have two pumps or not.
Thanks,
Steve
Thanks,
Steve
