Yes, I changed the subject of this thread. I'm going to use it to fully document this little project I've got going on now.
Layout options for the bottom electronics box are below. The various shapes represent the following items:
1. Large black rectangular box = stereo housing
2. Black circle = Floscan 9000 head unit
3. Small black rectangles = OEM Grady rocker switches
4. Small black circles = toggle switches
The switches are for the following functions associated with the Floscan:
1. Totalizer reset
2. Port/stbd. engine fuel burn select
3. GPH/MPG select
My original plan was to mount the Floscan and the OEM Grady rocker switches on a piece of black engraving stock and have the above functions engraved in the panel. The engraving will be done to avoid having to use generic stick or screw on labels which would make it look cheap. I wanted to used the OEM switches to try an maintain a consistent look with the rest of the instrumentation, but I don't think I've got the space on the panel for that. Keep in mind the white panel represents Seafoam Starboard. So, my options are...
Stereo to port, Floscan and OEM switches to stbd, no engravings or switch labels.
Floscan and OEM switches to port, stereo to stbd, no engravings or switch labels.
Stereo to port, Floscan and toggle switches to stbd, no engravings or switch labels.
Floscan and toggle switches to port, stereo to stbd, no engravings or switch labels.
Stereo to port, Floscan and toggle switches to stbd and mounted in a black engraved panel (use your imagination a little here...
Floscan and toggle switches to port and mounted in a black engraved panel, Stereo to stbd.
I'm pretty sure I want to keep the stereo to port so I have a clearer line of sight from the cockpit to use the remote. That way I won't have to get up from my seat next to the cooler to change the station or volume.
What do you all think, have I overlooked any other options. Right now, my favorite is the stereo to port and Floscan with toggle switches in the engraved panel to stbd. It's this one if you lost track from all the mess above...
