Hi all,
On my '95 272, there is an aftermarket "Mermaid" AC unit installed behind/beside the refrigerator. I don't have the manual with me at the moment, but can send specs if that would be helpful.
When I bought the boat, the dealers tested the unit and found it to be working. Installed a new control panel for me even so.
Things seem to work overall: the fans cut on and off like they should whenever the temperature drops above whatever I've set it for, etc. And from inside the cabin I can hear the water pump working, and see water pumping out of the thru-hull on the port side.
The thing is: the air coming out of the vents just isn't cooled. If this were a household AC unit, I'd say that the thermostat is working fine, but that the unit needed some more freon or something.
So, what's the most natural thing to check first for an AC unit that does everything right except cool the air it delivers? I'm a complete beginner in this area.
