Access to fresh water tank/ 232 Gulfstream 03'
Grady678
Atlanta / Hilton Head, SC
Slow leak somewhere in the fresh water system and wanted to see if anyone has same problem and how to fix. The pump is not on and within about 48 hours it's dry. Still usable, but, very limited quantity. Thanks for suggestions!
I used to have a 2004 Gulfstream and I believe the tank and pump are under the port helm seat. You access it by removing the draw insert that is on the side of the seat. Remove the trim screws and the hole unit pulls out. I had to replace my macerator in the same spot. I think I saw the tank and pump during that exercise.
