Adding tilt/trim gauges
gw204
St. Leonard, MD
What gauges do you have on there now? My '93 has the original Yamaha multi-function gauges and they have a series of horizontal bars (on the right of the display I believe) that indicate the trim level.
catch22
pennsville, nj
I found 2 styles of Teleflex trim gauges for Yamaha, pre 2001, (so far).
Main link - http://www.teleflexmarine.com/gauges-us/
Premier Pro Range series, (# 62728P) - http://www.teleflexmarine.com/document/ ... 5_1053.pdf
Lido Range series, (# 65505P) - http://www.teleflexmarine.com/document/ ... 5_1049.pdf
Also found a Teleflex "red international". Scroll down, near bottom of page, (TEL59609P)
http://marineengineparts.com/shopsite_s ... ge189.html
Boaters World website has the "Lido" series gauge - http://www.boatersworld.com/product/348501172.htm
The store might have other series.
94Sailfish
Ocean Springs, Mississippi
GW204, there are no gauges. I guess they were an option the original owner decided against. The links Catch22 posted show some good choices. However, though I can't remember where, I saw a combo gauge that showed both tilt and trim positions. Maybe I'll stumble on it again.
Concerning wiring, will the gauge(s) come with harnesses or not? Thx.
catch22
pennsville, nj
Doubt you'll get a harnes, if anything a short lentgh of wires. You'll need to tap into ignition on, (for function), nav lights, (for back light) ground and sender, (from outboard).
Your owners manual should provide wiring diagrams.
Page 43 shows gauge wiring - http://www.gradywhite.com/customer/manu ... wners_.pdf
