Advice on buying 83' 204c Overnighter !!
JAMIEK
Hey everyone, if you guys can give me some advice. A friend of mine is thinking of buying a 1983 204c Overnighter. The hull and transom seem to be in excellent condition. The only issue @ the moment is the marine plywood under the seats has rotted and is in need of replacement, also this boat was not covered. So my question is, because the wood was open & exposed, do you think it may have caused additional damge inside the hull ? Also, I didn't get a chance to check the bilge for fuel yet, do you guys know the time span of the fuel tanks rotting out, or should that even be a concern. If you can please give me advice on what to look for before he makes this purchase because he really loves the boat. This guy wants $3000- Boat, early 90's Johnson that he says runs fine (Motor not a huge concern, he has another one) & so, so trailer, probably need new hubs & tires. Also, that price ? What do you guys think, Thanks...!!!!!!!!!
striped bass
Watch Hill, R.I.
Without going into a point by point discussion, this is a high risk purchase. Too many issues for a boat that old which was left out side uncovered. The rotted seats should be the first red flag. Walk away until another day for a better deal. I don't mean to rain on your parade, but tell you friend to take a pass. He can do better.
cdwood
Hamilton/LBI N.J.
Second sb's comments. Unless your lookin' for a serious project, walk away. BEEN THERE, DONE THAT.
dlevitt
Aberdeen, NJ
I went through this "exercise" 2 years ago when I bought my '81 Grady. While the older boats can be great, they are not without potential issues. The first thing to look at would be the transom. It is not uncommon for water to get into the wood and rot it. I was lucky with mine, but decided to reinforce it with a penetrating epoxy to be on the safe side. Also, I was advised that the fuel tanks have about a 20 year life expectancy. If it is the original tank, you will most likely have to replace it and the hoses. Again, I was lucky as my tank was upgraded in 1999, but I would imagine that this isn't cheap.
Other than this, most other things may be considered minor and less expensive to fix. However, they should still be taken care of. The old grady's were great boats. Good luck with your decision.
