On my 1996 Johnson the amp meter pegs out when the engine is running
how can I check to make sure the gauge is not malfunctioning?
GW VOYAGER said:Bob
Maybe it is the voltage gauge
It shows about 13 v when the outboard is off but when I crank it the needle pegs out on the high end.
Do you think it is the voltage regulator?
Any help gladly accepted
GW VOYAGER said:Catch 22
I didn't notice anything on the Tach or lights only the volt gauge pegging when the motor is running and it just started Sunday.
It is a 1996 Johnson 225 ocean runner.
I've only had the boat a little over a month and everything else works fine
and I'm very happy with the boat.
