- May 6, 2009
- Los Angeles, CA
- Gulfstream
Hi Folks,
I have an issue with the port engine, a 2019 Yamaha 200hp. The tilt motor is intermittently not tilting. I have a mechanic checking it out. Sounds like it may be a bad tilt motor. I have had an issue on the same motor a few years ago, the main fuse (20amp) was popping randomly. A new wiring harness was installed under warranty, and had no issues with it for a couple years. In the meantime, I had the dealer that installed the motors, reconfigured the battery set up (and installed new batteries). I have one battery on starboard and two on port. The battery switches allow me to start either motor from either 1 or 2 battery position. That has been working fine for the past year or so. I am using a new mechanic that has come highly recommended by several people. He asked a lot of questions about the problem, if there were any telltale signs like it started slower or similar. He also reviewed the electrical system, from the batteries, to the guages and to the motors. It appears the tilt motor is not working properly. He also said it appeared that my battery cables from the batteries to the Perko switches should be larger. When starting the motor, with cowling off, we could smell faint heat and he said that could be a symptom of the system trying to pull a high load. The cables from the switches are factory (black, can't see sizing) and seem to be larger than the cables from the batteries, which are 4 ga. The pics are to show the factory cable size (black labeled "positive ++++ vs the battery cable sizes (newer red). My question (after this long winded preamble) is does this sound like? At first I thought it did, but as I think abotu it more, I'm not sure. Looking for opinions.
I also wonder if the previous issue popping the 20am main at the same motor, could be related.
Thanks in advance.
Len
Thanks in advance.
Len
