I am troubleshooting a problem on a boat with twin Optimaxes. While running various tests I had one of those DUH moments. The background:When coldish, and batterry switches set to 1 port and 2 starboard, neither motor will start. They crank over fine but wont fire. Some research online explained that those motor's ECUs are really picky about voltage and the ECU won't operate the injectors if it thinks voltage is a tad low.
Ok, I can buy that because I am seeing it happen.
Si when cold, I set both battery switches to BOTH and the motor fire right up.
Yesterday, I decided to set switches to 1 port and 2 starboard and as is often the case, the motors would not fire. Instead of changing both switches to BOTH, I changed switch 1 (port) only to BOTH and left switch 2 on 2.
Both motors fired up.
Last nigh while trying to understand what was going on, I had one of those "Am I really that dumb?' thoughts.
When one battery switch is set to BOTH and the other is set to 1 or 2, aren't both batteries electrically in BOTH mode?
I think they are and that could explain a lot.
The batteries may be getting a tad old or there may be a little extra voltage drop somewhere that causes a starting voltage drop that is out of range for Optimaxes. When the batteries are in BOTH mode, the voltage drop is effectively cut in half since each battery (in a perfect world) is supplying half of the starting current demand.
