I have an '81 Grady White with 2 batteries attached to a 1/both/2 PERKO switch. The engine is a '93 Evinrude 200. When I crank the engine from battery 1, everything is fine. When I crank from battery 2, I don't even get a click from the motor. The volt meter on the console goes to zero when I turn the key and returns to 10-12 volts after I release the key.  However, Battery 2 is still able to run the radio and GPS. I figured that it may be a bad battery and bought a new one. However, I still have the same problem - even with the new battery.
When I put a volt meter to each battery, I am showing 12+ volts. I even tried to crank (with the help of a friend) the motor with the key while I held the volt meter on the terminals. I figured that the bad battery would show a drop in voltage, but it didn't. I did this with both batteries with the same results. Since I'm an amateur at this stuff, was my logic in troubleshooting correct? If so, it seems that both batteries are fine.
Before I had to leave, I noticed that connected to the ground wires is some sort of metal plate which I assume ties some of the ground together (it also has a wire that goes to one of the engine bolts). It appears to have corrosion and I didn't have a chance to scrub/sand it. Is it possible that my problem could be corrosion and a bad ground on one of the batteries? Is it also possible that the switch can go bad? I didn't think it was the switch since I was still able to run accessories from the "bad" battery.
Other than cleaning the ground, which I will do anyway, can you recommend anything else to look for? Also, I took a 20 minute ride using both batteries on the Perko to see if charging would help. It didn't. I know that a bad battery would draw down a good one, but since I am assuming that the batteries are OK and I didn't shut down the motor while on the water, I'd be OK.
Any advice from the experts? Thanks in advance.
David
David
