- Dec 22, 2013
I have a Grady 228 with a 9.9hp kicker. I plan to troll using the 9.9 kicker (at probably 4-6 mph) for long, extended periods of time. I'd like to be able to imput many coordinate points in a line (one after another) and have my Autopilot do the work of getting the boat to them, while I concentrate on fishing. I plan to have a Humminbird 998 or 1198 Fish Finder that I believe needs to be compatable with my autopilot system. My primary use for the autopilot would be for trolling. This lead me to consider attaching the autopilot to the kicker. However, I also heard that a good autopilot can save considerable on fuel consuption while cruising due to their inherent steering efficiencies. I've read some people leave their primary motor (in my case a 250hp Yamaha 4stk) in the water while trolling and us that to steer (via conventional means or autopilot), while powering ahead with their kicker. Finally, I've also heard of people steering while trolling (again powering with a kicker) by physically linking both motors together so that as the primary steers so does the kicker. Is it detrimental to leave my primary motor in the water for extended periods of time (days)? If so, can the kicker be link steered with the primary out of the water? At 4-6 mph in the 2 mph+ gulf stream would dual steering (primary and powered kicker) be necessary for the autopilot to stay on course? I'd like to decide how best to set this up. I'd appeciate your thoughts. Also I'd like to know what would be a good autopilot system for this application. As you can probably tell this is all pretty new to me.
1995-Present .....14' Lonestar aluminum V-hull, :hmm 9.9 Evenrude 2 stroke (Boatacious)
1998-Present .....17' Grumman aluminum square stern canoe, 4HP Evenrude 2stroke (Mythril)
2013-Present..... 22' 1989 Grady 228g, 250HP Yamaha 4 stroke & 9.9HP Evenrude Kicker 4 stroke (Pole Bender)
