Bimini 306 forward fiberglass center insert
Saltwatershot
I have a 2006 Bimini 306 and was wondering if anyone knows how I can replace the fiberglass center bow insert. Ours was unfortunately destroyed in fire where it was stored. I’ve tried my local Grady dealer and even called Grady and no one has responded. Any suggestions would be greatly appreciated.
How long have you waited for a response? Dealerships are behind on being able to respond to emails on a timely basis because of increased demand and lack of employees. Maybe try calling directly.
I don't know what a "forward fiberglass insert" is, but if it's something that Grady made in house then there's not a whole lot of options. Try searching for the part number out of your parts manual, though.
Hi,
I have a 2018 306 Canyon. I ordered the insert in May of 2021 and received it in October 2021. I ordered via my local dealer.
At the time, GW was focusing on building boats, not parts.
I would suggest trying your local dealer.
If it is not available, then I can make a template for you from mine (assumes the space it the same) and then you can have one made locally or you can make one out of marine grader plywood and paint it with a urethane paint. It might be worth a try.
Did you send GW a note via the Cust Service link on their website? They are usually very quick to respond.
I was able to reach out to my local dealer and ordered a replacement insert, will probably be 3 months but they still make it so all will be good
