- Jun 30, 2008
- Ocean Pines, MD
- Express 330
My FP 4200 diesel generator cut off the other day after running all day. The fuel pump was original 2006 so I replaced it with a Facet pump (way way smaller than the original Walbro pump). I also changed the racor fuel and water separator filter which did have a little slime in it.
Started generator and ran for 30 seconds before shutting down. I believe I need to bleed the fuel system but wasn’t 100% sure how even after talking to FP service team. I disconnect the #5 wire and turned on system and pump ran but didn’t fill bowl up. I must be missing something here. Is there a trick to priming the system?
I can get it to start and it runs for 30 seconds before shutting down. Also changed oil and all was clear there.
appreciate any tips.
