- Apr 23, 2019
- Age
- 70
- Marlin
We had to replace the mast on my small boat lift due to corrosion and mollusk overgrowth. This occurred mostly due to neglect by the previous owner. New mast has a new zinc and I will use it enough to prevent mollusk growth. My question, is some of the corrosion due to galvanic reaction . I would assume there is a connection between the lift and ground at some point. Does this occur in this situation and are preventative measures indicated. A simple outlet/plug remedy would eliminate the potential ground connection except when in use.
What do others think?
