Boat survey question
Legend
Southern New England
Would you have a 2004 Sailfish surveyed if you were buying it. The boat has 145 hours. How much would you expect a survey to cost.
Do you consider the hour meters on these Yamaha engines tamper poof. thanks for your isights
Based on everything I've read, I'd seriously consider having a new boat surveyed. Hourmeters don't necessarily have to be connected but the engines should be able to connect to a computer for printouts of hours including hours within rpm ranges.
I just purchased a 2006 marlin with 32 hours on it, I paid for a complete survey. I also paid to have the engines compression tested by a qualified mechanic along with the printout on both engines (total hours, how many hours at what rpm, any fault codes, etc. The total cost for the work listed above was a little over a thousand. This also included hauling the boat, powerwashing the entire hull and relaunching the boat a few hours later after the out of water portion of the survey was complete.
To be perfectly honest, it was a waste of time and money. The only area of concern was the windshield wipers were worn and the first aid kit was inadequate. However, if i just spent my life savings and found out there was a expensive repair needed I would have been very upset. Kind of gave me piece of mind knowing everything checked out. Looking back, I would probably have done the same thing again. I always prefer having someone besides myself look at something before making a big (expensive) decision.
Assuming you want a full survey as listed above I suspect you are looking at around $500-$600. Add a few hundred for the engines by a Yamaha mechanic with the laptop and the software.
The hour meters on my boat were off by a few hours if memory serves me correctly. Not sure why.
Finally (sorry for the long post), I would certainly recommmend a survey. Pretty cheap 'insurance' on such a large purchase. Keep in mind I am the oddball that did both of my own home inspections, and I did not get a survey on the last three (much less expensive) boats that I purchased.
survey
Get the survey. It will be the best $300-$400 you spend on your boat.
But make sure you get one who is well recomended and will do a thorough job. In Mass, anyone can hang out a shingle and say they are a surveyor.
Always get a survey!!!! Alot could happen in four years even though that is
not an "old" boat. Its always better to have a second set of eyes to look
for what you may miss.
Make sure he is reputable and uses a moisture meter etc...
