Bolsters on 2006 282 Sailfish
Iceman2010
South Jersey
How do I remove the bolsters and does anyone know a good person in south jersey to redo them
Many of the bolsters are hung on brackets and held in place by screws inserted through the grommets on the underside of the bolster. Try using very thin flat tool to slide between the fiberglass and the lower edge of the bolster. If you slide it and it hits something solid, you probably hit one of the screws. Poke around in the grommet hole for the screw head. There won't be a screw in every hole, just a few to keep the bolster from sliding up and off of the brackets.
Reactions: Iceman2010
