It is likely the prop shaft seal. I tried replacing mine, twice, still leaks, I think the prop shaft has a small nick in it causing this. You could try replacing seal, only other option as mentioned is to replace the entire lower, about 600 bucks. Mine leaks so little that I need to top off reservoir 1 x / season, and that works for me.
