Bow Thruster - Spares you need.
Hoghunter
Snohomish, WA
Just thought I would post this as an FYI. If you have one of the Side Power Thrusters installed by Grady I would strongly recommend that you get at least one each of the shear pins for the prop and the electric motor.
The one for the prop is easy as it's right behind the prop. However, the one for the motor isn't quite so easy but certainly fixable by the boat owner.
I was out last weekend and all of a sudden when I went to use the thruster it just hummed as if free wheeling but no prop. I figured it was probably the shear pin for the propeller as I have seen that one when servicing the prop shaft. Well that one was fine. After much reading of the manual I finally spotted a shear pin listed on the schematic back page of the manual for the electric motor. That requires taking up the floor under your table and then taking out the four bolts that secure the motor to your gear box. Total time to get to the shear pin was about 15 minutes. Now I've been waiting four days and still waiting for a replacement pin. I ordered three of them.
For reference I've had my boat 2 years next month and don't use the thruster a ton.
bow thruster
I had the same problem at about the same time. I wonder if 2 years is the average life span of the shear pin inside? If so, I probably need to replace mine again on my 2004.
Re: bow thruster
That's interesting that yours happened at 2 years as well. Mine wasn't broke it was just worn down to where it would stay in the slot. They use a compression type shear pin that seals as you pound it into the slot.
shear pin
their should be a spare set of pins attached to the side cover of the thruster
the carbon steel one is for the motor and the ss one is for the prop hope this helps
tony 33grady SALLY-ANN
Re: shear pin
Well I wasn't lucky enough to have them attached. I did a good inspection looking for spare pins and nothing.
Thanks for the thought though.
