Bunk dimensions for Grady White Marlin 2006
Gary Hambell
What is the recommended length and width for Grady White Marlin boat lift
I'd shoot an email to GW cust service in parallel with the ask there. The same hull is used on all the 30' line so folks with the CC, DC and WA should be able to help.
Assuming 2009s and 2006s are about the same spacing, the bunk spacing would be 51 1/2 inches center to center. The longitudinal center of gravity is approx 10 feet 2 inches off of the transom. You would want that point somewhat centered on the lift.
Reactions: Meanwhile
magicalbill
Indiana
Two extra things:
I have a 2018 Marlin resting on a 16K lift. The boat is 12,500 lbs loaded with 350's so the extra safety margin seemed wise to me.
I also have 20 ft bunks. I think the more hull that the bunks come in contact with and support, the better.
My lift is perfect for the Marlin. I assume, (dangerous word) that an '06 Marlin is the same hull.
I would bet they are the same but worth checking with GW. Pretty expensive to modify except when required. As stated molds are used in a few different boats.
I think so too Bill. This is a classic measure 3X, cut once.
89hoya
Fisherman 180
Here you go.
  • 2021 GW Bunks.pdf
