Cabin ceiling liner in my 33 express is drooping
Sundowner
The cabin ceiling liner in my 33 express is coming off.I have tried glueing it with a 3M spray glue but is doesn't last.Does anyone have any suggestions.
Ajon
The one over main cabin area? What year?
BRO-CAL
Following. This is happening in my 2007 Seafarer 228 as well. On the to do list.
ElyseM
highlands, nj
is it just the vinyl or the actual backer board?
my vinyl came off. i had to pull the backer board down carefully and restrech the vinvl. GW only left about 1/2 inch or so overlap which was defintley not sufficient. I got GW to send me the 2 sided mounting tape to reattach the backer board. if you pull down the board and the vinyl is stretched and secured with Gorilla tape, you have my boat.
good luck, ron
ElyseM
highlands, nj
narrow strong putty knife. work from one end to the other gently. can't remember exactly but i think tape pieces were about 6" long. dome lights have to come off first. my lights where wired direct; i cut them and installed bullet connectors for ease.
good luck, ron
