Canyon 336 Stern Trim Piece
Maingotm
Canyon 336
Does anyone know where I can find this small trim piece for my 2011 Canyon 336? I’m not even sure what it’s called. Looking for P/N and where I can purchase. Thanks. IMG_1982.jpeg
GW sells em, see your local dealer. Its a band aid at best. You can removed, caulk and re-install new ones. Eventually you'll have to do what the factory should have done, remove the motors and re-glass the joint completely. Don't wait too long or you'll be in the transom rebuild zone costing thousands of dollars.
Thanks Fishtales. I’m going to give them a call in the morning.
I totally understand. I'm in the same position with 2005 F250s. Care for them and run them till the repair bill is excessive, then bite the bullet and repower. May loose some time on the water, but it's really the only option once they get up there (age and or hours).
