- Jul 3, 2021
- Age
- 63
- Freedom 235
The previous owner removed the bezel and I think there's water damage. Has anyone replaced a 6Y9 gauge and have any documentation or recommendations? Thanks!
Thanks for the response! The gauge continuously beeps and flickers between the combo screen and settings screen.
you are correct. The actual gauge bezel is missing. I don't know if that means that water can seep in but your gauge doesn't look too badly damaged.
Unfortunately new gauge is pretty expensive.
You can buy a new bezel but at just under $200 it would not be a good decision if the gauge itself is bad. Did this gauge ever work while you owned the boat?
Do you have the manual with the configuration instructions? One thing to note is that the 6Y9 Plus can only be used on Digital Electric Control engines. Is your motor A DEC model?
New bezel
I think you can view the manual here
Yamaha Marine Instruments 6Y9-2819U-E0 User Guide | ManualsOnline.com
Marine manuals and free pdf instructions. Find the marine product manual you need at ManualsOnline.marine.manualsonline.com
Thanks! Yes, that would be worth trying before replacement. Much appreciated!!Hmm - my best guess is that some water got behind the silicone seal on the right and is shorting out one of the buttons, possibly the menu button given what you're seeing. It may be possible to clean the contacts under the seal, but you might want to see if you know an experienced electronics hobbyist to help you.
If you do go at it, make sure the power is off and if moisture did indeed get under the seal, you'll have to find a way to reseal it from further moisture. If you do get it working, I'd replace the bezel as it may help to keep water out!
