Converting from Hydraulic Steering to Fly By Wire
jmoneilthe2
Woodville, Florida
I recently purchased a 1992 GW Seafarer 22, which had the original hydraulic steering. The steering is can be difficult at times, very stiff. I was hoping that I could get some feedback on converting to Fly By Wire. I have seen several systems for sale and was wondering if it is a good move.
im not sure, but i think you need to have newer power.
even so, hydraulic steering shouldnt be stiff or tough. have you looked into whats wrong with your current set up?
Reactions: Sardinia306Canyon
Check out Dometic’s website. They own SeaStar. Don’t think they allow diy for their electric steering system, if that’s what you’re interested in.
There is Optimus for Outboards out there. not sure a 30+ yo 22ft boat is a reasonable candidate for that upgrade.
I have not heard of anyone on this site do that upgrade.
Have you done the troubleshooting steps with your steering? Might be an "easy" fix.
How old is the motor? It could be the swivel bracket in the motor that is binding.
Not to be a downer, but I'd have what you have looked at and optimized at the lowest cost. You're looking at a 35 year old hull, systems and likely older power. Keep it safe and up but don't go crazy with upgrades is my input.
as noted, shouldn't be stiff. might need to do a full purge or update helm and actuator. i don't believe the electric steering is going to be cheap. and that would still require a helm and actuator change anyway.
good luck, ron
What do you mean by Fly by Wire? Electric steering?
What outboard/s
What year hydraulic steering components?
There is no electric steering conversion kit i am aware of, except you buy a outboard who has it already built in.
I had many outboard combinations and all with Seastar helm pump and hydraulic piston/s and none of my boats had stiff steering. Not even my BW 23 Outrage with twin Yamaha 150HP 2 stroke, HDPI and then F150.
Stiff steering is mostly a binding steering tube due internal corrosion aka rust and im most cases due old, hardened and/or inappropriate grease when using the grease gun to grease the steering mechanism.
When you grease the zerks you need to pump so long till grease squeeze out on top and on the bottom of the steering tube. If this does not happen or is neglected there is most likely a plug of old grease plugging the tube and avoid that the grease can fill it completely.
If this is your case then use a heat gun on low setting and slowly warm/heat up the vertical steering tube and try to use the grease pump to break the grease plug free. Do that so long till the grease plug becomes soft and get squeezed out and continue pumping till the new , fresh grease comes out. Do not overheat the steering tube nor damage the other things around!
The last resort would be unscrewing the zerks and fill the tube with CRC or WD-40 what would slowly dissolve the grease, but thats a messy job and you need to pump in a lot of fresh grease to clean the steerin g tube from the CRC/WD-40 to avoid that fresh grease get dissolved too.
The other, but less frequent problem could be on your hydraulic system, helm pump or hydraulic piston.
To verify what is the problem, disconnect the hydraulic piston and turn the outboard by hand, they should turn freely.
If they don't turn freely then steering tube is binding, if they turn freely then most likely your hydraulic system is the culprit.
Reactions: Halfhitch
Not even close in terms of reliability..replace the helmet pump..not too hard..boatsteer.com is good to work with.
