Crack in pulpit - need fiberglass person (OC MD)
grady33
Ocean Pines, MD
Does anyone know a good fiberglass repair guy in Ocean City MD. I have a crack in my pulpit (272 Sailfish) and need to get it taken care of ASAP. From the looks of it (and according to GW customer service), it appears that water may have gotten in through the top bolt and swelled the wood causing the crack. Anyone else experience this problem? Thanks, David[/img]
Pulpit
Hope you have better luck than me...2 guys who did warranty work on MA area GWs wouldn't touch mine. Seems on the 23' Gulfstream, GW supposedly made a 2 piece mold, sprayed gelcoat, clamped together and pumped the middle with 'who knows what'. Issue is gelcoat cracked and replacement won't stick to that middle filler. Ended up sanding, priming and painting (matched perfect but not same).
On my 92, Grady used end grain balsa in the pulpit, same stuff hull is cored with.
How did you crack it?
Did it get below freezing down there this past winter?
Mine had standard 2X lumber inside (now marine ply).
It looked like Balsa, may not be.
I have some drips comin down from a pulpit rail bolt nut when it gets hot out, will have to take it apart end of season and see what's going on in there.
Fiberglass guy (Jim's Marine) is coming by this week to fix. Took a look at it and it seems that either the 2 bolts on top were tightened too much or water got in through one of them and caused the wood to swell. Doesn't look bad now but probably better ($$$ wise) not to wait to fix.
