Cracks on transom - should I be worried?
merlin25
Avalon, NJ
I am looking to buy a 22 Grady White (2001). I noticed two small 1-inch cracks on the transom on either side of the outboard. Its hard to see in a photo but they appear to just be on the surfacegel coat. Any reason to be alarmed or cautious about buying the boat or is this just normal due to the age of the boat?
[/img]
Have the boat surveyed. The only way I would feel comfortable with any used boat is by having a surveyor or at least a fiberglass specialist & mechanic go over it.
You can have a nasty looking gel coat and/or crack that is in perfect structural condition and conversely picture perfect gel coat/surface that is on the verge of delamination. You never know so get in an expert.
surface gel cracks in non-critical areas are no biggie.....but high stress areas like the transom, especially where the engine is mounted, absolutely. Get a survey as LI and SZ have suggested...best bet is to have it checked by your local Grady dealer...they may know the boats history as well. If the transome is not wet, it may be minor cracking...I would even go far as suggesting an aluminum backing plate to help distribute the load better.....see what the mechanics say..ask the previous owner for his service paperwork and where he had it done!
It sounds like they are just surface cracks which do occur at the transom since that area takes a lot of load, gelcoat is not very forgiving and goes not flex well and cracks. I agree I would still have the boat surveyed regardless, that way you know it is not something more below the surface, or a repair resurfacing, but it is likely it is nothing, but spending a few bucks now to know is better then finding out in a year or two and having major work needed. I would though highly recommend taking care of those cracks to prevent them from expanding, because they will and down the road a few years from now could become the cause of issues. You can get the gelcoat repair kit from a Grady dealer to match your years gelcoat. Drill out the 2 ends with a drill in reverse,.....always drill through gelcoat in reverse or you will chip it badly. The drilled ends relieve the stress and will stop the crack as long as the drilled hole is slightly larger then the actual crack itself, the hole and crack is then repaired and covered with the new gelcoat and if done neatly will be very hard to notice, and likely only you will know its there because you did the work, anyone else will have a tough time ever realizing it.
