Creaking deck cover on 2018 Gulfstream
Wineprof
Creaking deck cover driving me crazy!
I bought a 2018 Gulfstream 232 in 2020. Last season the deck cover over the gas tank started to creak when you step on it. The noise is maddening! Has anyone experienced this problem and found a solution? In the newer Gradys they do not screw down that cover instead they fasten it with a epoxy product called Plexus MA 300. If the Plexus fails, the cover moves and rubs against the deck and makes a terrible creaking noise. I have researched this problem with local marinas and fiberglass repair shops. They tell me that they have seen this happen on a number of Gradys. Apparently, there are two schools of thought for the fix. One is to remove all the caulking around the cover and apply a small amount of Plexus near where it came detached. One shop tried solving the problem by reapplying Plexus told me they had repeated failures. Each time the caulking had to be removed then reapplied adding more labor dollars to the job. The second method is to remove the caulking, somehow cut out any remaining attached sections of the Plexus so the cover can be removed, (easier said than done apparently). Sand the underside of the cover and the deck of any residual Plexus. Shim the area that the deck cover sits on and screw the deck cover down (as Grady did before they made this change for esthetic reasons). I am trying to find out how often this separation has occurred so I can decide which way I should have the problem addressed by the fiberglass specialist in my area. I asked this question of a Grady Customer service rep in an e-mail with a video of the noise but did not receive a reply. Any recommendations would be appreciated.
Plexus is a permanent adhesive I believe. Hard to believe that GW uses it on the hatches that require removal for tank inspections and replacements. I'd want to remove the cover, install a rubber barrier between the hatch and the deck and then seal with something that allows you to get the hatch up if needed in the future and then caulk the space between the hatch and deck.
Reactions: SkunkBoat
Don't know if I like "no screws" or don't like" no screws"
Screws cause the core to get wet. and they are ugly and cause chips.
I take up my tank hatch every year. Its screwed down and then silicone or 4000UV to seal the gap.
no screws would be nice if you don't need them to hold the hatch flush to the deck.
MA300 is a two part adhesive. Must be tough. I don't think I like that. Its like using 5200.
Must be very hard to remove the hatch.
I guess its better than a solid deck liner and having to cut the deck to get at the tank.
Do the new Gradys have a plastic tank?
Wish I had a good answer for you. Sorry
I agree. Plexus isn't meant to permanent. If may be used on the deck to hull seam but I find it hard to believe it was used on the tank lid. I have been wrong in the past though.
