Cuddy Carpet
Salem_Max
Massachusettes
First time boat owner and just got me a 1985 Overnighter and loving it! The cabin carpet really needs to be replaced (I would not have chosen white) but I can’t find the cabin dimensions posted anywhere. Does anyone have some info or insight? 37E16FEE-0CCC-4128-842B-11618FFB2882.jpeg
My Overnighter was pretty bad inside too with a lot of black mildew into the carpet.
I cleaned it with the upholstery wand on our Bissell carpet cleaner. Used a mix of hot water, carpet shampoo and oxyclean.
It came up like new and has stayed that way.
You can do the same thing with the mix in a bucket with a hand scrub brush and use a wet/dry shopvac to pull it back out of the carpet which is basically all the Bissell is.
What, you don't like the monkey fur? :)
When you say "dimensions"... are you asking for the dimensions of all of the different "pieces" that will be needed? No such thing exists. Measure what you have, add them together, to get a rough idea. Then you "cut and paste" as you go. The ONLY way you'll get something like a template is by using the old pieces after you remove them. Even then, I would still cut oversize and trim to fit on install.
