Cushions for my 22 seafarer
Johnny Dollar
looking to purchase or have upholstered cushions made.
Any owners have any info?
Are these the cabin or cockpit cushions? Where are you located?
There is a guy in Hull and Winthrop that does them as well as B21 in Rockland. Fabric Warehouse has the vinyl, sail thread and other stuff if you want to attempt yourself. I got the rest (foam, ss staples, re-used zippers etc) off Amazon. A
I did my white upholstry a while back. I'll post a link.
I'm going to do the interior cushions this year. I got some marine fabric from Joanne Fabrics for about $16 a yard. I measured what I need approx 6 yards. My plan is to use the backsides of the existing cushion set. They are black mesh like material and the zippers are on them. This saves a lot of work. I'll use a seam ripper and disassemble each cushion to use as a pattern. I'll sew the sides inside out to the top piece and then the bottom piece to sides. Flip the fabric inside out thru the zipper and then either re-use or buy 4" dense foam off Amazon. I think I can re-use the existing foam if so, this should be fairly quick.
I am going to take the (3) white vinyl pieces that go over the hatch and the to the sides of the hatch as well as the two that go on the livewell and rigging station to Bld 21 in Rockland and get a price. Probably will spring to have these made up. I'll start a thread when I do this and keep you in the loop.
Johnny Dollar
Thanks for the info Fishtales i look forward to following you to see how you're doing
we have been doing a ton of work to my Grady still trying to finish up lots of electrical work.
i thought about doing the cushions etc Might be a good winter project
Yes, I did. Same with grommets, you gotta test them in the environment before using.
