simple measurement and calculation
Use a level. Draw a horizontal and vertical line on the transom to make sides a and b of a right triangle. The hull is side c.
Don't try to go to the keel with the measurement. Its rounded! To get accurate results, make the horizontal line at least 12".
The vertical line
must be plumb. It will be 4 7/8" for a 22 degree hull. I just did this on my 2000 265 express. I get 22 degrees which is what I expected.
Roughly 4 3/8" for a 20 deg hull
Because you used a level, the triangle is a right triangle. You can check yourself by doing it again on the other side of the transom.
Use the calculator on the internet. I added some notes to the screen shot.
