Tashmoo is 100% correct, the boat needs to be dunked to form a scum line. Have it taped off maybe 1/2" inch above that( boat needs to be dunked with gear and full gas, otherwise account for that and it makes it much harder to do, atleast have full fuel if nothing else. The scum line will not harm the hull, just looks nasty. Use collinite 920 hull cleaner and clean the hull, it will come off. If that does not work use mary kate on off hull cleaner, but then you need to apply wax to the boat, both products will leave you with bare gelcoat which you do not want, you want something over it. Was your hull waxed for the season, if not that is not good, the salt will eat the gelcoat instead of the wax. If it is only a brown mark not much can happen but you need to have it redone this fall when the boat is hauled. If you never change it, where the boat sits in the water over the years can be absorbed into the gelcoat and swell the hull, especially if it is not protected correctly. I'm hoping the dealer used a hard paint for the first application. If you plan to stay in a marina from here on out, use an ablative paint over the hard, it will last longer and wear off the boat as you use it where a hard paint stays on and needs to be soda or sand blasted off after a few coats. I would recommend using Micron Extra paint. Not a fan of petit paints, interlux has been a better paint for NJ waters, especially if your marina does not have good flow and the water gets warm. Micon Extra can be applied over most hard paints, but using an interlux hard paint is best. If it was not used and it was a cheap paint, call interlux to see what to do, likely you will just sand some paint off clean it with paint thinner and paint over it without a problem.
I would be very angry with the marina, they should have did the job right. Seems like they skimped out on a bit of work by not doing the lines properly. I think they should cover the fee to have the boat hauled and do much of the work for you, but I'm not so sure I'd trust them again either, plus they will likely not fit you in any time soon just to spite you, depends on the brokers integrity. Sorry to hear about the bad paint job. Also find out what paint he used to see if he charged a fair price, regardless you need to know what it is for future paint applications.
